AP disconnected while cloning pc on lan Reply
catok@yahoo.com
5126 1 2018-3-13 11:08:17
Edited by catok@yahoo.com at 2018-3-13 11:16
Hi all,
  We are using Ruijie products in our network.  AP controller - WS6008 with AP520I and AP530I. Moreover 5750 and 6220 switches. We found that all the APs are down while there is a multicast cloning on the LAN (PCs are connected by LAN Cable). The AP Controller report huge access from its port. Is there any problem on settings with AP controller or switches? Thanks a lot.
   WS6008 (port 1) to 5750 switch. 7 VLANs.
Cato
0 2018-3-15 14:45:15 View all replies
encapulsate them to specific vlan ?
Releated Posts
