How many ip camera can be carried by EST? Reply
GTAC-Harvey
3999 0 2022-5-15 21:56:19
EST310:
EST350:
To guarantee the transmission quality, the environment should be kept as open as possible to reduce the interference.
At the same time, it is recommended to adjust it to the best alignment angle with the signal strength indicator or Ruijie Cloud APP.
RG-EST310 V2
config
There are no replies.
