Unable to print the Voucher Reply
Arun Raj
3629 1 2022-8-12 21:07:06
Hi,
It appears to be some change in the portal and we are unable to find the tab through which we use to print the wifi voucher for distribution.
Kindly look into this and resolve the issue. Thanks
Farhan
administration@fujseng.ae
(0529093145)
Other
Other
0 2022-8-15 09:30:24 Solved View all replies
Edited by Patrick at 2022-8-15 10:32
Dear sir,
You may follow the screenshot down below to print the voucher:
Patrick
