How to recover the password of Ruijie switch if it doesn't support "main_config_password_clear" command Reply
GTAC-Bancroft
4562 0 2023-8-15 13:13:23
1.        Topology
2.        Configuration Steps
1. connect console cable to the switch
2. Refer to chapter system management>console management
1). Manually reboot the switch
2). Press Ctrl+C when system rebooting
3). Press CTRL+ Q,then input "ubootui", press ctrl + p as soon as you hit enter
4). Then put the following commands:
s29xs#setenv runlevel 2
s29xs#run linux
5). Run the following command and notice the space between the commands.
~ # cd /data/
/data # ls
/data # mv config.text config.bak
/data # sync
/data # reboot
3.        Verification
Login in switch it can directly access
Set the new password for switch
RG-S5300-24GT4XS-P-E
Configuration Switch
There are no replies.
