Portal Page Fails to Authenticate Users to use Internet Reply
Louis Ngatau
1286 7 2024-11-13 20:15:25
"I’m experiencing an issue with my Wi-Fi voucher system where the portal page fails to complete authentication. When users enter their voucher code, it loops back to the portal login page instead of connecting them to the internet. Has anyone encountered this problem or know a solution? Any help would be greatly appreciated!"
Troubleshoot Guide Wireless Troubleshooting Network Setting Others
0 2024-11-13 21:23:36 View all replies
Hi, could you check as follows?
  • Check whether the voucher code is correct.
  • Check whether the voucher has already been bound to other users, and the user number limit is 1.
  • Check whether the voucher code has already reached the user number limit.
  • Check whether the voucher code has expired.
0 2024-11-14 01:07:53 View all replies
GTAC-Rachel replied at 2024-11-13 21:23
  • Hello, I already double and triple check, however still got issue with login....
    0 2024-11-14 13:50:30 View all replies
    Louis  Ngatau replied at 2024-11-14 01:07
    May i confirm that all users have this issue? Could you also check whether the login url is https://www.ruijienetworks.com? and it will help if you share the login fail page screenshot, thank you very much.
    0 2024-11-20 14:56:56 View all replies
    Hi, I have the same problem as Louis Ngatau even though I used the url
    0 2024-11-20 15:18:01 View all replies
    Kathy Barrera replied at 2024-11-20 14:56
    Hi, if you failed in login with voucher code, could you help share the login fail page so we can better understand the situation? and may i confirm that all users have this issue?
    0 2024-11-21 13:36:31 View all replies
    We have had this issue since the last update.  It was fine prior to that.  Hope this gets fixed soon.
    0 2024-11-21 14:23:11 View all replies
    Ceazar replied at 2024-11-21 13:36
    We have had this issue since the last update.  It was fine prior to that.  Hope this gets fixed soon ...
    Hi, sorry for the inconvenience. if you failed in login with voucher code, could you help share the login fail page so we can better understand the situation? and confirm whether all users have this issue. Please also check your configuration according to the steps posted above, thank you for your kindly understanding.
